Silverado DIY and Useful Threads This section is for Do-It-Yourself articles and other informative FAQ threads. If you would like to submit an article, contact a member of staff!
2006 Silverado 3x3 issues
Old Nov 10, 2020 | 11:47 AM
Chris Thomas's Avatar
Default 2006 Silverado 3x3 issues
My 4x4 only seems to work when the weather is really wet, or frozen cold, other than that no lights show up on the switch. I have replaced the switch, the actuator, tccm, and the pigtail that goes to the actuator, also cleaned the grounds below the drivers seat on the frame. Are there any other spots on the wiring I should check?
Old Nov 10, 2020 | 12:13 PM
oilcanhenry's Avatar
Just a guess but the water or ice might actually be what's causing this. I'd get some Permatex Dialectical grease, clean all your connection up then add the dielectric grease to the inside of the connectors. Might be a good idea to heat them up first and get any moisture out, A portable hair drier works great for that, and also to keep the dielectric grease warm.,Not only will the grease keep water out but you won't have any corrosion issues. And it's cheap!
jason78
Dec 6, 2015 11:14 AM
guetta09
Uplander
Feb 11, 2015 3:32 PM
cnolans@cox.net
Uplander
Aug 14, 2012 10:41 AM
chemman
Uplander
Dec 19, 2009 10:09 PM
2006trailblazer
Feb 24, 2009 1:58 PM
