00 Silverado Cold Start Problem
My truck is having problems starting in temps 32F or less. It turns over but won't start. Once it does start (if it even does) it runs fine. Here is what I know it is not as I've replaced....
Battery
Fuel Pump
Fuel Filter
Fuel Pressure Regulator
Spark Plugs
Cleaned MAF
Tested Engine Coolant Temp Sensor
Installed Engine Block Heater Plug...no difference
Thoughts????? Even though I cleaned the MAF, I tested the first two prongs for resistance and got nothing......so maybe MAF? I'm not sure what else to try.....
Battery
Fuel Pump
Fuel Filter
Spark Plugs
Cleaned MAF
Gasoline engine ? Pull a vaccum on the engine and look for an intake leak. I had the same problem you describe here a couple years ago, faulty intake gasket. Once the engine starts the the problem was gone in seconds. Made it very difficult to diagnose.
LanceV
Silverado & Fullsize Pick-ups
August 24th, 2011 12:59 PM
gtfireman
February 3rd, 2011 5:18 PM
Thermool
June 20th, 2009 6:41 PM
izod
February 14th, 2009 2:42 PM
carlsndfw
December 7th, 2006 7:43 PM
