"05" silverado 4.8 ltr. V8 fuel filter question?
Old Aug 11, 2010 | 11:57 PM
cazador223's Avatar
Default "05" silverado 4.8 ltr. V8 fuel filter question?
My brother has the above mentioned truck and has been told that the fuel filter is part of the fuel pump assembly, located inside the gas tank. However, I looked under the truck and saw a in-line filter, I thought maybe his truck was a transition model but nobody lists a fuel filter for his year and engine. Any and all help is appriciated.
Tom
Old Aug 12, 2010 | 12:37 AM
s34n's Avatar
do you have pictures? it would help. i have an 04 1500 5.3 and was also told that my filter is part of the pump assembly. i however have looked many times inside the frame rail and there is no filter to be found. good luck
Old Aug 12, 2010 | 11:02 AM
therewolf's Avatar
Hi cazador223,
Welcome to the Chevy Forums.
You've got the filter(easily available in most parts stores) on the frame rail many of us wish we had, so consider yourself lucky.
You have to relieve fuel pressure before you replace the cartridge. Be sure to use line wrenches and bolt loosener to get the old filter out, or you may tear up your fuel lines.
Old Aug 12, 2010 | 11:08 AM
GM Parts Direct shows a listing for the fuel filter for the 05 Silverado however it does not show weather it is an internal or external filter, its list for $16
Old Aug 17, 2010 | 12:35 PM
juddkennedy's Avatar
@therewolf, how do you "relieve fuel pressure" as you mentioned above?
Old Aug 17, 2010 | 4:44 PM
Opening the gas cap will relive internal tank pressure, when you first loosen the fuel line do it slowly to bleed off any pressure, you can also use a fuel pressure gauge on the fuel line check port to check and relieve pressure....
DeHartShadow
Oct 22, 2013 10:52 AM
rssmith1976
Apr 1, 2013 11:10 PM
christianadler
Mar 11, 2008 7:53 PM
kaneless
Jan 15, 2008 12:27 PM
einstein2nd
Sep 20, 2007 10:33 AM
