Old Aug 10, 2015, 7:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
05 Siverado oil pressure too high
Old Dec 7, 2009 | 9:50 PM
RTR09's Avatar
Default 05 Siverado oil pressure too high
Recently my oil pressure guage started showing 80 psi but when i turned the ignition off the gauge would only go back to 40 and not all the way to zero. I changed the oil pressure sending unit and now the neddle goes all the way past 80 and as far to the right as it can go. Do you think it is the gauge or could it be something else?
Old Dec 8, 2009 | 2:45 PM
nauticstar87's Avatar
I've read that sometimes the fuel gauge will do that when theres a bad ground, so possibly you have a bad ground.
Old Dec 8, 2009 | 4:52 PM
desrtrat's Avatar
sounds like the stepper motor is going bad in the gauge. you can check by putting a mechanical gauge in and see what psi you have, or use a scan tool.. my money would be on a bad gauge/cluster..
good luck
not_a_car_dude
Sep 15, 2013 7:41 PM
mprovence
11
Oct 9, 2012 1:24 PM
Mille Racer 69
15
Jan 1, 2011 9:12 PM
mygreenihc
May 7, 2009 9:41 PM
GermanyD2009
Jan 24, 2009 10:19 AM
