07 silverado 6.0 q??
hey guys i have had my 2007 silverado new body style for about year and a half now..i love it ..it is a crew cab vortec max.....anyways i was wondering if anybody has tryed swapping there cam in this motor yet..i know it is the ls2 motor but what cams fit it ..there is nothing anywere that i have found that ses you can use the ls1 cams in it or what will work for the truck and not the cars???? but i def think it is time to start beefing up the motor ..more hp..367 i am used to it ..plus it kicks in so late" at such a high rpm" that is not really fun..lol fast on the top but not qiuck..please get back to me ...tony c in rhode island..
[IMG]local://upfiles/18742/AFF3243F03CB412FAFEF6ABBD57810E2.jpg[/IMG]
RE: 07 silverado 6.0 q??
first i would spend about $375 in a custom tune by nelson performance. get them to remove 80% of your torque mangament and it will eliminate most of the delay. plus on my 6.0 (i have to run 93, 10:1 compression) on 93 octane it gives something like 30-35hp to wheels. not to bad for just a tune.
give it a try before going through the trouble of swapping cams. then if you decide to do it, call them up, tell them what youve done, and you get a free retune. best of both worlds.
good luck
good luck
thanks bro..were do i find the "nelson tune" web site.. sounds good..and also the dealership told me not to run high test gas in it ..they said 89 was good enough and that i would not see a diiference even with 87/...i guess this is not true..there dushbags..
ttyl tonyc
ttyl tonyc
www.nelsonperformance.com : i personally have to run 93 on my 06 V-max due to the 10.1:1 compression but the new V-max runs at like 9.6:1 so yes you should be able to run on 87 but it might ping a little on cheap gas. on my 06 5.3V8 nelson said it was 16-18hp to the wheels for 87 and about 30 to the wheels on 93 (i went 87) but 93 with a tune will make a big difference and it is only about 5-6 more per complete fill up. if you are running 89 just go up to 93 becuase money wise you wont see a big difference.
im probably going to go 85% torque management removal. just remember if you beat on it with any TM removed you might break something. also you might want to keep your stock PCM (they will charge you a core charge) so as not to void your warrenty. when you need service just pop your factory one back in. good luck.
Wheatly, HP tuners, and Nelson.
Most have a life time free re-tune. Where they ship you your new computer and then you ship them the old one back... Just pay for shipping.
You would want to re-tune your truck for a cam swap anyways, so thats a good place to start before you throw in a cam.
You wont see a difference in higher octane unless its tuned for it.
here is a good link describing Torque mangament and why GM just needs to MAN THE HELL UP!!!!
also why your 07 feels sluggish even with a damn impressive motor.
Nelson's saves us all LOL
http://www.edmunds.com/apps/vdpconta...1/pageNumber=2
