07 silverado battery light
Old Sep 24, 2013 | 4:23 PM
dontony's Avatar
Default 07 silverado battery light
A couple of weeks ago I attempted to jump start a coworkers truck from mine. I connected the batteries directly to each other and he started his truck. His truck died and would not idle and we gave up. Two days later my battery light came on, my battery is 2 months old. I replaced the battery and 2 days later the light came on again. Did I screw up my voltage regulator in my alternator?
Old Sep 24, 2013 | 5:33 PM
Official GM Rep
dontony,
That was very nice of you to assist your coworker but sorry to hear you now have a concern with your battery. If you are interested in having your GM dealership look into this please let me know. You can reach out to us via private message.
Erica Tiffany
Chevrolet Customer Care
Old Sep 24, 2013 | 7:53 PM
That would be my guess... if his alternator or charging system was shorted out it could have very well have done the same thing to yours...
Might try having the alternator load tested, but do check all of your fuses to make sure its not as simple as a fuse..
Old Sep 24, 2013 | 8:25 PM
Put a volt meter on the battery with the engine running and see if the reading is at 14 volts. If it is around 12 volts, the alternator is not charging.
Old Sep 25, 2013 | 6:19 AM
dontony's Avatar
At start up, the gauge in the truck shows about 15 volts, and if I drive a while it goes to 14. The autozone tech put a portable tester on the truck and said the alternator and starter were good. I will start looking at fuses today. Thanks for the replies.
Old Sep 25, 2013 | 7:20 AM
Please do keep us posted on what you find
Old Sep 25, 2013 | 6:16 PM
dontony's Avatar
With the truck off I have 12.45 volts at the battery. After start up, I am getting 14.25 volts. Any suggestions on which fuses or relays to check, or pull and check them all?
Old Sep 25, 2013 | 9:20 PM
MDTAHOE's Avatar
Professional Mechanic
The battery light is really an alternator light. It comes on when the truck does not see charging voltage. Some alternators start to fail when they are warm. You need to have the alternator tested while the battery light is on as that is the only time what ever is failing is bad for now.
Old Sep 26, 2013 | 6:10 PM
dontony's Avatar
Well, it wasn't the 180 dollar starter. I guess no good deed goes unpunished.....
Old Sep 26, 2013 | 6:22 PM
dontony's Avatar
I mean it wasn't the 180 dollar alternator, not starter.
