Notices
Sponsored by: DashLynx
1997 1500 4.3L stumbling and missing
Old February 16th, 2013, 7:56 PM
jordan.morgan's Avatar
Default 1997 1500 4.3L stumbling and missing
ok so here the issues the truck will start idle and rev fine,when I pull out it does fine till it hits about 2000 RPMs then it starts stumbling and the shift light comes on. Once i shift it will do fine. Till the same RPM Range, However if i give it more gas and pass over to about 3000 RPMs then it runs like a top. problem only seems to be at near 2000 RPMS. At highway speed that is cruising RPM. so this is a issue.
We have had plugs, wires and rotor button and Cap and coil all replaced and no change MAF sensor and fuel filter and pump replaced and no change.
I need Help Im racking my brain here....
Old February 17th, 2013, 8:54 AM
Marcus Baker's Avatar
It sounds like the fuel pressure regulator / 'spider assembly' to me.
Old February 18th, 2013, 10:20 PM
Yea I was hopeing that would not be the issue how hard is it to replace that
Old February 24th, 2013, 10:51 PM
Mike Vosburg's Avatar
Default 1995 missing
I gust hade the same thing replaced oxgen plugs wires roter and cap anb re greesed ele chip
Insjde rotter cap the last helped the most
Cananot
April 20th, 2015 1:35 AM
BlaneR
August 2nd, 2012 5:23 PM
winkelfish
August 23rd, 2010 8:55 PM
93chevyman
March 12th, 2010 1:13 PM
Jeff1968
November 3rd, 2007 12:05 PM
Quick Reply: 1997 1500 4.3L stumbling and missing
