Notices
Sponsored by: DashLynx
1998 Cheyenne 2500
Old March 7th, 2021, 7:33 PM
Ryan Whary's Avatar
Default 1998 Cheyenne 2500
I adjusted the valves 3 days ago. The first day was nice, no lifter tick, more power. The 2nd day i started to hear a bit of what i thought was a knock. My lifters never ticked at idle or low rpm previously. But if i got on it at all they would almost sing.
Now its doing nearly the same thing.... At low rpm and idle the truck sounds great. Get on it even a little bit its sounds like frogs on a pond at dusk. All high pitched and chirpy. But it still runs good, i havent lost any power.
Im thinkin its a bent or a burnt valve but at this point i need some outside assistance.
Old March 8th, 2021, 7:17 PM
oilcanhenry's Avatar
How exactly did you adjust the valves? The manner in doing so makes a big difference. I'd not use it until this issue is repaired.
Old March 9th, 2021, 6:08 AM
Ryan Whary's Avatar
I quarter turned the crank 8 times. Each turn i would spin the rod as i took the lash out. After the 8th turn and adjustments, i went an additional 3/4 turn.
Before i started anything i loosened all the rocker arms, took all tension whatsoever out and started from scratch.
Old March 14th, 2021, 5:03 AM
Here is another way to adjust the valves, while the motor running. A 3/4 turn on the rocker stud nut after all the slack is out of the rocker/valve rod. I've heard of people going a full turn, but I never had to do so.
Old March 14th, 2021, 9:54 AM
Gumby22's Avatar
If there was no lifter noise, why did you adjust the valves?
Here’s the recommended adjustment procedure.
Old March 14th, 2021, 11:07 AM
hanky's Avatar
There are little clips made to prevent oil from being shot all over the place from the oil hole on the rockers. This allows you to check for a noisy lifter with the engine idling without getting an oil bath.
ravenwolf69 (December 27th, 2021)
Rich m
Chevelle & El Camino
July 3rd, 2020 11:14 AM
Ianmac
1988 - 1998 (GMT400)
21
March 22nd, 2020 11:34 AM
terrydo
2014 - 2018 (GMT-K2)
October 17th, 2019 3:47 AM
Quick Reply: 1998 Cheyenne 2500
