2010 Silverado Throttle Position Sensor
I have a 2010 Silverado that began showing the classic symptoms of a bad throttle position sensor. When I cranked it this morning, the truck began idling extremely rough and the cluster showed ENGINE POWER REDUCED and SERVICE TRACTION CONTROL. My question is can I replace only the throttle position sensor (TPS) or am I forced to replace the entire throttle body? Autozone shows that you can purchase the TPS separate.
Any input would be appreciated.
TR
TR
Addition to the original post:
I just unplugged the wiring harness to the TPS and plugged it back in. I cranked the truck and all seems well except that the Check Engine light is still on. Does this mean the TPS is the issue?
Equinox Owner
Equinox
26
January 4th, 2022 11:45 AM
