2500hd CAB LIGHTS?
RE: 2500hd CAB LIGHTS?
dropping the headliner, laying out the holes evenly,wiring them up right to come on with the running lights,sealing the hole's up good .(would be best with threaded inserts),reinstalling headliner,after checking that it works. first some truck's have a harness up there for lights if it was ordered that way .
And also i have the XM radio antenna up there from factory im guessing it will be ok in the same spot.. its toward the drivers side door
depends on how you lay them out ,if you have never done them before have some body repudidable do them or you will live with the problems forever .check how good off quality work they do and there rep for handeling warrenty claims is .
cpolarbear
June 17th, 2008 2:22 PM
DSG_2500HD
May 9th, 2008 8:30 AM
bhenderson10
Silverado & Fullsize Pick-ups
10
April 11th, 2008 12:00 AM
