Last edit by: IB Advertising
Browse all: Transmission
- Chevrolet Silverado 1999-2006 GMT800 Transmission Shifting Problems and Diagnostics
Guide to diagnose trouble and recommended solutions
4L80 transmission problems
#31
4L80e transmission problems
What did you come up with? Thanks in advance.
#32
2003 silverado 2500hd 4l80e shifts down a gear or 2 ,Dash reads Transmission hot
New 4l80e gets to 150-160 readout says Transmission Hot then shifts down 1 or 2 gears and will not go back to overdrive.Is that a sensor issue or a fluid issue?
#33
Better late than never....
You'll have to drop the pan to fix the connector (new wire harness) easy job. Once fluid makes it's way into the connector you'll end with all sorts of shift/no shift issues. Also clean out the other end well with electrical contact cleaner. Also good idea to replace both the shift solenoids while you're in there and turn the force actuator up 1/2 turn.
ChevyRS6
Silverado & Fullsize Pick-ups
October 9th, 2014 7:42 AM
