Notices
Sponsored by: DashLynx
96 K1500 Hard starting
Old July 28th, 2013, 4:51 AM
sbh111's Avatar
Default 96 K1500 Hard starting
Ok, so let me give a little info on this truck.
Its a 96 K1500 with the 5.7L V8
I bought this truck for almost nothing from a guy that let it sit for 4 years.
I got it since it was worth more as scrap then he was asking and if I could get it going it was a rust free nice truck.
To get it going, I had the local shop put a new tank and fuel pump (the whole assembly) in it. I replaced the fuel filter, the plugs and wires, Battery.
My symptom: It cranks for 5-10 secs before it catches. Then it stumbles for a second or two until it gets up to speed. After its running it sounds great and has no issue. No codes!
I have tried to hold the pedal down full and half way and even pump it. I have tried to turn the key right to start and tried to wait for it to prime. I can hear the pump when I turn the key for a few seconds.
It doesn't matter if its the first start of the day or if I just shut it off to go into the store for 5 minutes.
I am wondering if it could be the distributor or anything else you people could suggest.
I have the tools to check most things but not the knowledge of how to check them. So your advice and maybe a little info on how to follow it would be great.
Old August 3rd, 2013, 5:09 AM
sbh111's Avatar
Default Update
So I changed the Distributor cap and rotor but have no change.
Please can someone help me out here?
Old August 4th, 2013, 12:47 AM
Jkevin's Avatar
Might be intake leak, once running spray a little starting fluid
Around base of intake to see if Rpms pick up. If so, reseal the intake. Common
Problem over time. Be careful that you don't ignite the stuff though.
Old August 4th, 2013, 6:40 AM
shamrock246's Avatar
What is the fuel pressure and how long will it hold it for?
Old August 4th, 2013, 10:44 AM
claydogg84's Avatar
I agree with Shamrock, check to see if the fuel pressure is holding or dropping to nothing when you shut the truck off.
Old August 4th, 2013, 10:47 AM
sbh111's Avatar
Ok I have a vacuum guage and a pressure guage, but what am I pulling to check it. Sorry for my ignorance. I have just never checked fuel pressure.
Old August 4th, 2013, 5:52 PM
Get this setup or something like it and there is a schrader valve on the fuel lines on the drivers side of the engine looks like a tire valve that's where you check it should be 62-66 psi key on engine off and not how fast it goes down
Tester
Fuel Pressure Tester & Fuel Injection Pump Tester
Procedure
Part 2 -How to Test the 'Spider' Fuel Injector Assembly (4.3L, 5.0L, 5.7L)
fastfirebird
16
September 24th, 2009 6:41 AM
chevy4ever
May 22nd, 2007 3:47 PM
papiklfish
December 8th, 2006 11:36 PM
billyjoe72
October 21st, 2005 4:33 PM
Quick Reply: 96 K1500 Hard starting
