Notices
Sponsored by: DashLynx
99 rodo z71
Old May 11th, 2012, 11:45 PM
Doug Roberts's Avatar
Default 99 rodo z71
How much play is in transfer case ?? I get a thud so jacked truck up rear end is OK . The play is from transfer case .the ujoints look good
How do I open and look at chain and if floppy what's needed
Old May 12th, 2012, 10:20 AM
cleveland63b's Avatar
grammar and detail would be helpful but there shouldnt be much play in the tcase itself, pull the plugs check the fluid and if you can see inside rock the driveshaft back and forth see if you have a floppy chain
also when is it clunking? I'm assuming when you're going into 4wd?
Old May 12th, 2012, 7:33 PM
Lol phone fixed it and was late ill fix it
Old May 12th, 2012, 7:39 PM
No clanking in 2w at a start like ujoints are bad but its in case I think its chain like u said
Old May 14th, 2012, 7:35 PM
So can I fix chain or is it just replace them
99ChevyZ71
14
August 29th, 2012 8:22 AM
jgray152
February 19th, 2012 11:12 AM
Quick Reply: 99 rodo z71
