99 tahoe 350 loss of coolant, cant figure out.
#11
You won't usually be able to see it when you change your oil. I never did I didn't know the coolant was getting in my oil until I took the valve cover off. That would be the easiest way to tell if it is in your oil because when the coolant mixes with oil it sticks to everything and won't come out when you change your oil. It is most likely your intake gasket or even the intake. The gasket is reatively cheap and you can find an intake at a junk yard for about $100.
#12
yes
since i just noticed where you tried a block tester, I know you have differentiated between head/intake gasket.
i can not mention the head gasket enough, mainly because
some people have grandpa saying "the book is wrong, you only need an intake gasket"
after replacing intake gasket, they discover white steam pouring out the exhaust has reduced but still exists
so then they test the head gasket, and discover they must go a 2nd run through the intake.
i learned
i learned
#13
yes
i learned
i learned
SIVAONES
April 2nd, 2011 7:47 PM
tboz
Express & G-Series Vans
May 21st, 2010 9:08 PM
