Notices
Sponsored by: DashLynx
Adding Cruise V-6 Silverado
Old January 8th, 2011, 9:03 AM
rbickham's Avatar
Default Adding Cruise V-6 Silverado
I have a 2006 Silverado with a V-6, Auto Trans. and I would like to add cruise control. Can I just change the turn signal multi switch and get the module,cable and brackets from a salvage yard. Is it a plug and play install or is there more work than that? I have read that all the wiring is there even if the option is not ordered from the factory. Are the aftermarket kits any good?
Thanks, Rod
Old January 9th, 2011, 1:27 AM
CJ_Tiz's Avatar
Rod I had read somewhere in this forum all you need to do is get a fuse, relay and signal multi switch. I dont remember where but i'm sure if you search it will come up.... I dont know if this worked for the guy or not also.
Old January 9th, 2011, 7:07 AM
rbickham's Avatar
V-6 models use a throttle cable and you need the module that mounts under the hood and has a cable connected to the throttle. I just need to know what else I need.
Thanks, Rod
Old September 23rd, 2016, 9:54 AM
zziggy's Avatar
scs4342 or rostra 1223 both are an all electric servo cruise. I found them at Aftermarket Cruise Control, Auto Air Conditioning kits
mxdad777
Express & G-Series Vans
September 23rd, 2016 9:52 AM
latropa
April 17th, 2014 9:27 PM
tkdunn
June 20th, 2010 11:15 PM
wolfman
Sonic (Aveo)
June 11th, 2008 11:09 AM
Boosted82
October 31st, 2006 11:21 PM
Quick Reply: Adding Cruise V-6 Silverado
