Airbag light
Old Apr 4, 2012 | 7:13 PM
David Moritz's Avatar
Question Airbag light
I have read some of the threads that have covered this and also seen other sites with this problem and i think i caused it. I have a Chevy 2008 1500 Silverado and the airbag light came on after I had cleaned it and had the seats shampooed. I saw and one forum that the light was caused by the seat sensor could I have done this i only cleaned the drivers seat and always clean the car with warm water, no chemicals then add a dash protectant. Help would be appreciated.
Old Apr 4, 2012 | 10:53 PM
EinST's Avatar
Welcome to the forum. Your air bag warning is on but you seem to be nonchalant about it. You realize the air bags won't deploy if you presently get into a collision? Get it scanned for air bag codes and go from there. There are even a few TSBs, depending.
Old Apr 5, 2012 | 9:34 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> David Moritz,
The SDM may need to be replaced. This is just a suggestion, not a diagnosis. I encourage you to have the vehicle inspected.
Louis
GM Customer Service
LoFaroNYG
Sep 26, 2013 11:23 PM
01impala89
Nov 25, 2007 12:39 PM
davidmangrum
Oct 3, 2007 8:23 PM
wayner52
Jun 27, 2006 7:43 PM
