Last edit by: IB Advertising
Browse all: Steering and Suspension
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Lower Control Arms
Step by step instructions for do-it-yourself repairs.
ball joints
i need to replace my upper and lower ball joints on my 05 silverado z71, i have been reading that its recommended to replace the entire control arm instead of joint itself? im a newbie to this..any advice would be great (pros and cons) or reason why
lower ball joints are probably welded in. which means grinding the weld without messing up the whole arm. way easier to buy whole control arm. use a good wax crayon or paint pen to mark all your alignment bolts and such. this will help to get everything back together close to where it was. alignment will be required.
hey then you wont need coil spring compressors. I'd loosen your torsion bar keys to reduce any pressure up there(use a torsion key compressor tool). If you replace your control arms, look into getting new bump stoppers before the operation, some times the old ones don't come off willingly and are trashed. Stock ones are pretty cheap, if you expect to be hauling some heavy stuff, or snow plowing I'd look into getting the ones made for snow plowing. measure the length of how deep your torsion key bolts are, before you start any adjustments there, so you can put them back where they were at.
im soon to be in the same situation, my lower control arm's bolt holes for the shocks are really bored out in a oval shape, makes an annopying chattering sound. I was thinking of welding the holes shut then drilling it out, but i think them control arms have seen enough life, being 26 years old.
