Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2014-Present: Why Does My Blower Motor Not Work?
Guide to diagnose trouble and recommended solutions
Blower motor issues...
I have a 1997 silverado...I tried a new blower resistor and checked the fuse...my blower motor intermittently works...sometimes only on high and sometimes not at all...has anyone had this issue before..
I have to agree with "rfordy" I have a 98 silverado 2500. mine only worked on high, I replaced the blower resistor and it works fine... If you blower motor is going bad it will burn out the resistor again. Make sure it is good, no sqeaks, or squells....
You also need to check/replace the harness. When the resistor goes it can burn/melt the wires in the harness connector. You should also replace the blower while you are at it. As the blower wears it pulls more current than the harness was designed for. Too much current and everything shorts out. A common Silverado and Chevy in general problem.
I have a 1995 Silverado. replaced the blower switch and now it only works on high. Do you know where the resistor is located?
mikebruce700000
Sep 23, 2015 6:05 PM
