Notices
Sponsored by: DashLynx
brake lights
Old November 9th, 2010, 9:37 AM
julosibia's Avatar
Default brake lights
good morning guys. got up today with no brake lights whatsoever. the two at the tail and the third one on top of cab dont work, all else.signals, running, flashers, all work. what should i look for and where. thanks a million
it is a 94 c1500 w/t,with the 6 cyl. auto.
Old November 9th, 2010, 11:39 AM
Mille Racer 69's Avatar
Fuse or relay likely went out.
I think your fuse block is on the drivers side of the dashboard facing the door.
And there are some relays under the hood by the windshield wiper fluid IIRC.
When you turn on your headlights, do the back taillights light up?
Maybe you haven't been noticing that 1 by 1 your brakelights have been burning out
Until now when they are all burnt out.
Your problem is 1 of these things, you just gatta look into it to find out which.
Old November 9th, 2010, 9:11 PM
Professional Mechanic
MDTAHOE's Avatar
Most likely the brake light switch is the problem.
Old November 10th, 2010, 9:34 AM
julosibia's Avatar
thanks, i do check the brake lights often, and dont think they are burnt. reading thru the search function i see some have had the same problem, and either the brake switch or turn signal switch have been mentioned as the possible culprit. i have to say that i have noticed sporadic issues lately with the turn signals. once it blinked fast as when a bulb is burnt, but it wasnt and have not done it more, and a couple times when you put the signal it feels like it has not engaged (clicked) and i reapply the signal and then it engages.trying to narrow it down so i dont buy the wrong part. after all electrical parts are not returnable.. thanks for your replys.
whats your guess?........do i have to remove the wheel (steering) to replace the signal cam switch?
Old November 10th, 2010, 8:59 PM
MDTAHOE's Avatar
If the third brake light (high mount) does not work it can not be the turn signal switch. It does not run through the T/S switch. Only the left and right ones do. Third goes from brake switch to light.
Old November 22nd, 2010, 4:19 PM
julosibia's Avatar
thanks a lot guys. replaced the brake switch and voila !!!! they all work... god i love this chevys.all so simple and inexpensive. $10.99 at advance, and 10 minutes of work...........so far so good.
PatrykKoul
April 26th, 2023 9:14 AM
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
cowboys
December 18th, 2006 12:28 AM
Quick Reply: brake lights
