Chevy doors
Not 100% sure, I know you can't use the door panels, in 95 they changed the interior to a more rounded look, the best way is to check and see if the plug in the dash is the same, otherwise you might be able to take all the power options out of the 94 door and put them into the 95 doors, best way to check that is pull two of the doors apart and is if all the mounting locations are the same. Hope this helps
G-Force
July 20th, 2009 3:18 PM
mrhaney
May 10th, 2009 10:05 AM
