cts sensor
#12
You said "the readings are bouncing all over the place" when you measured the resistance across the sensor terminals (with the electrical connector off). Is it the same with the new sensor? I assume you know how to use the meter (VOM or DVM?) and the meter itself is good?
#13
old one ohms set at 20k. on the bench settles on 195 ohms. new one the same
don't understand why with cts unplugged runs and shifts as it should . plug it in and it bucks and slips between 2nd and 3rd. and stumbles all over itself between 1st and second . after first to second shift holding pedal constant it will slowly catch up to pedal. then stumble going to 3rd. have had a code 67 for 2 years. that is the only code it shows now. unless i unplug the cts.
#14
code 67 is for the torque converter clutch circuit try unplugging it from the trans and see how it runs i had this on a 85 citation that was bucking turned out to be the brake light switch causing the clutch to come on and off while driving
Sean
97 4x4 burb
Sean
97 4x4 burb
#15
Supashack
Corvette
August 26th, 2014 6:27 PM
Chevrolet Forum News
June 4th, 2014 6:08 PM
