Frustrated
Frustrated
I have a 04 base model Silverado V-6 5 spd. It spits and sputters going up thru the gears, I get into 5th and it seems to run fine. Just had a tune up a few hundred miles ago. Need help, I don't want to tear up the drivetrain.
If a repair shop did your tune-up take it back and have them look at it again.
I'll bet the problem is still there in 5th gear - seeing that you're not accelerating it is not nearly as pronounced as it is under a load.
It really sounds like a cylinder misfire which could be anything from a small piece of carbon on the plug electrode to a dead cylinder.
You are correct about the issue still being there in 5th gear. I noticed this morning on my way to work. I also noticed under hard acceleration it doesn't seem like it's there or not. If it is I can't notice it.
dartlord2001
1988 - 1998 (GMT400)
89
January 1st, 2024 5:30 PM
GaryB-2009
Silverado & Fullsize Pick-ups
15
June 25th, 2022 2:19 PM
snowjay
November 16th, 2009 1:55 PM
