Fuel Problem
Fuel Problem
I have a 98 z71 with a 5.7 vortec, the truck just died at highway speed tonight, i replaced the fuel pump in february, i checked fuel pressure and it reads 0 psi. but i can hear the pump run, has plenty of gas, even added some to make sure it had gas.could it be the fuel pressure regulator or the filter? Thanks, Russell
RE: Fuel Problem
Odds are another bad pump.
The pressure regulator will not cause a 0-psi reading that I have ever seen and the fuel filter would have to be completely 100% clogged which is possible but also not very probable.
hunter10220
May 18th, 2011 8:37 PM
harascho
May 11th, 2009 2:10 AM
ross_boss08
August 4th, 2008 2:41 PM
