How to get air out of coolant system?
Old Dec 9, 2010 | 3:34 PM
railer689's Avatar
Default How to get air out of coolant system?
I posted earlier with a 96 silverado blowing cool air when its cold out...Well I replaced the heater core today but its still blowing cold air?? I was told there could be air in the system...How can I burp or get the air out ?
Old Dec 9, 2010 | 7:19 PM
gotstylez's Avatar
    Add a mixture of one-half water and one-half antifreeze to the radiator. Fill it right up to the top.
  2. 2
    Fill the overflow/coolant reservoir with the same 50/50 mixture.
  3. 3
    Leave the radiator cap off, turn the engine on and let it run until the radiator "burps": You will see the coolant level drop and may see or hear a large air bubble come to the top as the system burps.
  4. 4
    Keep an eye on the temperature gauge throughout this process.
  5. 5
    Refill the radiator to the top and coolant reservoir as needed.
  6. 6
    Put the radiator cap back on.
  7. 7
    Note that if the engine runs hot after this procedure there may have been another pocket of air that "burped." Let the engine cool down and then add more coolant to both the radiator and the coolant reservoir.
<!-- google_ad_section_end() -->
Old Dec 9, 2010 | 7:53 PM
DoubleO7's Avatar
at step 7 above, leave the rad cap on and ad fluid to the overflow.
As the rad cools, it will suck fluid in to fill the system.
Old Dec 9, 2010 | 9:55 PM
MDTAHOE's Avatar
Professional Mechanic
Are you sure the t-stat is not bad
dlaroche
Oct 29, 2014 7:17 PM
chevy619
19
Feb 5, 2012 8:42 PM
surfandride
Jan 16, 2011 10:05 PM
Flying Low
Corvette
Mar 29, 2009 7:56 PM
shell67
Avalanche
Aug 25, 2008 11:37 AM
