Hypertech question
#11
RE: Hypertech question
can someone please help with the rev limiter and shift points question.. the rev limiter goes up in 100 rpm increments and the shifts points say +/-500 either way.. whats the best place to set them at??
#12
id have to look at my box but i believe i have my hypertech set at these settings:
87 octane tune
rev limiter: 6200 (factory was at 5900)
shift points: 1-2: +200 (puts it around 5800 or so)
2-3: +200
3-4: +100
shift firmness: 50% (should be an increase of %50)
gears: N/C
tires: N/C
fan temp: N/C
87 octane tune
2-3: +200
3-4: +100
gears: N/C
tires: N/C
fan temp: N/C
#13
would that work with a 4.3L VORTEC? i had my uncle do mine and hes not in town and i cant get in touch with him. my friend has the same truck as mine but 05.
#14
the print out i have states redline is at 5900 Rpm on a 4.3 as well. so taking it up to 6100 rpm is not that big a deal since you wont be at that rpm for a long time.
if you have an auto transmission the shift points should work fine. all i did was go out on a highway and stomped it from a dead stop and then wrote down roughly at what rpm the transmission shifted at. then i added +200 rpm to them and then did the same thing and it dropped back into its power band insted of dropping below it. you might have to do this yourself to see how it will feel on your 4.3.
as for shift firmness, that is personal preferance. i like a firmer shift than stock and 50% gives it to me. you might be ok with 25%, you will have to drive the truck some to tell what setting you like.
good luck
good luck
white03
Silverado & Fullsize Pick-ups
April 15th, 2014 6:58 AM
Danistheman1234
May 25th, 2011 7:27 PM
bhwakeboarder
March 16th, 2007 3:55 PM
