It's cold (new member)
I have a 1999 Silverado blowing only cold air, fan works great, mode works, it changes zones, but no heat and its 8 degrees outside. Any clues? Thanks
You may need to get down at the lower vents and verify that the blending door is opening/working. Probably whats happening is the heat is there at the heater core but is not being allowed to enter the vehicle becasue the door is not opening because its stuck or is not working anymore.
Ok, further info: the radiator is full, I haven't checked the door but I did check the heater hoses, one is warm and the other is cold. If the door doesn't open will the water still circulate through the heater core?
bub2000sierra
Silverado & Fullsize Pick-ups
May 30th, 2012 10:15 PM
mdec950
May 11th, 2012 9:44 PM
Supertwins
July 4th, 2011 11:39 AM
Mille Racer 69
17
November 7th, 2010 4:19 PM
