Marker lights on roof issue
I was replacing one of the lights when by mistake my screw driver touched the inside where the bulb inserts and all five of the lights stopped working. I checked every fuse possible and bought additional bulbs. Test light will not work on the unit, i'm so frustrated any and all advice please.
Thank You
2001
2500 HD
8.1 L
Thank You
2001
2500 HD
8.1 L
This the formation of my marker lights
They are all out now
Its a fused part of the wire that acts like a fuse. If it is blown it needs to be replaced. I don't know for a fact that you have a fusible link, but maybe. Did you test all of the fuses or do a visual check?
I used a test light and pulled some fusses that were some possibilities all were fine. There is a box on the firewall on the driver side that has wiring leading to it, it appears that the wiring could be comming from the lights on the roof. I appreciate your help would rather not pay the dealership to figure it out.
I missed a fuse while testing it was the (int prk) 15 amp fuse on the interior fuse box. After finding the fuse I also had to replace the assembly that the bulb goes into. Had to go to dealership for it, thank you for the help
patk214
February 26th, 2014 9:14 AM
