My fuel pump went out, NOT
Hi everyone, Its 3 weeks now. My truck is running just fine. I pull into the store, engine is off a good hour. Go to start it, it just cranks. I got gas that day. past experience fuel pump. Just did it in my 89 couple years back simple. New pumps in new filter of course. Go to start it just runs for a second. Wait my girlfriends grand prix had theiftlock I had to unlock once. LOW AND BEHOLD my theift lock is activated also. lets go back. Yes I did do pressure check after installing the new pump. OK new pump new filter code is disarmed and--------------same runs for a second and dies! this is all after it was running fine till then. now its gotten past my troubleshooting skills. Has anyone else had this problem? Any help would be great. Thanks
My 2005 Silverado 5.3 with 142,000 miles on it..Never had a problem till last week.
Had over 3/4 of fuel from a full tank still in it.When to town and was park about an hour.Came out to go and will not keep running, It was towed to my home and Check the fuel pressure and it had none. Fuel relay and fuse is good..Book said it could be the fuel pump has gone bad..No codes shows up..Replace the fuel pump that also has the build in fuel reg and filter with it.So that all new now. Still does the same thing..Act like it would start if it had some fuel pressure..Anybody here that can help me out,I would sure like to know something else to try..Thanks
wirespider01
March 7th, 2013 11:49 PM
Eggie329
August 11th, 2011 11:56 PM
hunter10220
Silverado & Fullsize Pick-ups
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
