Old Jul 27, 2015, 12:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
nnbs crank position sensor
Old Jun 3, 2012 | 7:49 PM
topwhop1977's Avatar
Default nnbs crank position sensor
i have a 2007.5 4.8L crew cab 4x4 silverado ( the new body style)
today while leaving camp when I started the truck I got the check engine light , i have a edge programmer so i checked the code and got a crank position sensor, i reset the code and drove the truck about 3 hrs on the hwy home with no issues and no engine light came back on. once in a while i get a stumble when slowly accelerating, i already changed the plugs and it made no difference,
has anyone changed a crank sensor yet and if so where is it located.
thanks
mike
Old Jun 3, 2012 | 8:57 PM
Exhausted's Avatar
Simple change
It's located on the rear underside of the block on the passenger side a 10mm bolt holds it in place
Old Jun 3, 2012 | 9:43 PM
do you need to remove the starter to access it or is it the sensor just infront of the starter
thanks again
Old Jun 3, 2012 | 9:49 PM
Exhausted's Avatar
Man I can't remember it's really close
But removing the starter is just two bolts and it drops down
No shims
Old Jun 4, 2012 | 10:41 PM
would you change it or wait untill another fault shows, i bought one anyway
Old Sep 12, 2012 | 11:52 PM
gasman98's Avatar
That happen to my 2007 Silverado Z71 while a 3 hour non stop drive at 80MPH. Stopped for gas and when I started the engine it cranked hard and had a rough idle. Check engine light went on afterwards. Plugged in my SuperChips programmer and a crankcase senor came up. I cleared it on my programmer and problem solved. Havent had any problems after that. Yes, you do have to remove the stater but easy to remove. Youtube has many videos how to change. Good Luck
deepstuff
Sep 24, 2011 8:43 PM
bigq11
May 11, 2011 12:53 PM
Vince
Astro
Oct 1, 2010 6:07 AM
bbish0p
Feb 8, 2010 2:17 AM
kidm28
Oct 20, 2006 6:18 AM
