Oil consumption issue - 2001 Silverado
I recently acquired a 2001 Silverado (always garage kept) that has a small 4.8L V8 engine, 4 wheel drive, short bed and the standard issue fair showing 67k on the odometer. I have used the truck over the past 10 months and consequently changed the oil twice (3-4k between) not noticing any low levels of recaptured used oil (seemingly at least 4 quarts).
However, the 'check oil level' warning light came on after 1200 miles since the last change so I added a quart and have parked the truck, looking for leaks or other issues. I have found clean concrete under its parking bay, little to no oily residue on the bottom of the engine, and no noticeable blue smoke in it's exhaust.
Any ideas??
I have searched on-line and found two seemingly constant threads regarding Chevrolet V8's of this era which include:
1. possible faulty or poorly-designed PVC valves that cause oil consumption, a replacement PVC valve has been manufactured by Chevrolet.
2. Engines in this era just burn more oil due to their ring design and need ring replacement in order to alleviate the issue.
I'm grasping at straws here, I love my truck and I don't want it to succumb to an untimely end due to something curable.
Thanks in advance for any assistance!!
Dave
P.S. I just did a compression check and it was well withing spec.
Any ideas??
Dave
john1231989
May 4th, 2017 12:21 PM
clanofwolves
Silverado & Fullsize Pick-ups
January 21st, 2012 7:31 AM
Rocket10
27
November 1st, 2011 8:35 AM
clanofwolves
June 17th, 2011 8:59 AM
