Notices
Sponsored by: DashLynx
persistent brake lights problem
Old July 18th, 2009, 10:10 AM
rhino3855's Avatar
Question persistent brake lights problem
Howdy everyone,
Here's the problem: my brake lights and rear turn signals do not work. My tail lights and reverse lights work and the turn signals in the front work. I figured it would be the turn signal switch as about two months ago my emergency flashers also quit working and they are all run off of the mutlifunction. I replaced the switch but the same problem persists with the brake lights not working. I am sure I installed it correctly as the cruise control, wipers, and emergency flashers all work correctly. Any thoughts of where to look next?
The truck is a 2000 Chevy 3500 old body style.
Old July 18th, 2009, 8:46 PM
Professional Mechanic
MDTAHOE's Avatar
Does the third brake light work? The third does NOT run through the turn signal switch, so if it works most likely the turn signal switch is good. You can look at the brake light switch however that would not effect the turn signals. One problem I see very often in check trucks is the sockets go bad and can not carry the ground to the bulb. Visually they will look ok. You can try to add a temporary ground in the socket at the bulb (not on the wire, but where the bulb touches the socket) for testing if they work then you need new sockets. If I remember correctly it is a assembly that bolts into the tail light and is available cheap in the "HELP" section at Autozone or Advance Auto Parts.
Old July 19th, 2009, 10:08 AM
rhino3855's Avatar
The third brake light DOES work. I will check the grounds and see where that takes me. Thank you for your input.
PatrykKoul
April 26th, 2023 9:14 AM
TRUCKDIVA
July 22nd, 2013 6:48 AM
DOBERDEWD
December 11th, 2011 11:35 PM
skdevore
August 26th, 2009 10:18 PM
cowboys
December 18th, 2006 12:28 AM
Quick Reply: persistent brake lights problem
