Notices
squeal at certain RPM range
Old October 7th, 2011, 3:00 PM
Nodakchevyguy88's Avatar
Default squeal at certain RPM range
I have a 2005 Silverado with the 5.3 and i have a squeal that only happens when in drive or reverse. The sound happens only between 1200-1600 RPMs its sounds like a belt but both are brand new. The sound has been there for 5000 miles at least and hasn't gotten any worst or any better. I wonder if anyone has had this problem or encountered something like this. Any ideas would help. Thanks
Old October 7th, 2011, 3:09 PM
Welcome to the forum...
It might be worth replacing the tensioner pulley or possible the whole tensioner... don't apply any dressing to the belts, if you detail the engine avoid getting anything slick or slippery on the belt or pulleys....
check for anything that might be contaminating the belt like a leaking AC compressor or oil from a leaking oil pan...
Just some things to check and consider...
Old October 9th, 2011, 10:12 AM
OLD WRENCH's Avatar
Take the belt off and see if you sitll have the squeel.
burrell22
August 9th, 2013 1:19 PM
nels5
October 16th, 2012 10:38 PM
ccross
August 17th, 2010 10:17 PM
B-Rad
March 20th, 2010 5:48 PM
espy59lc
January 1st, 2009 1:16 AM
Quick Reply: squeal at certain RPM range
