Notices
Sponsored by: DashLynx
temp guage
Old January 1st, 2008, 5:27 PM
athomas's Avatar
Default temp guage
have an 03 2500hd with 6.0L temp guage reading 210 when truck is ice cold. two days ago guage read about 245 while going down the road pulled over check hoses upper was warm lower not so warm had driven 6 miles. thought thermostat was stuck so called wrecker. work at a parts store soyesterday pick up thermostat and today put it in. temp guage still reading 210 after two days sitting. ran truck down the road8miles temp reads 230. put a temp probe on the cyclinder heads they read 160,water pump reads 160,upper hoses warm to touch lower hose coldany suggestions
Old January 1st, 2008, 11:47 PM
northey87's Avatar
Default RE: temp guage
Well the easiest place to start would probably be the temp sending unit and work your way to the gauge, sinceyou have already established that it is not a bad thermostat. Just a suggestion.
Old January 2nd, 2008, 3:54 AM
athomas's Avatar
sending unit is wired into the pcm on these trucks no dtc when you start the truck all guages reset but the temp
Old January 2nd, 2008, 8:46 AM
ZX1100F1's Avatar
Most likely a bad gauge stepper motor, very common on this year instrument cluster.
Have your dealer reference GM Document ID # 2037454 which will cover the gauges under warranty for an extended period (7 years or 70,000 miles).
Old January 2nd, 2008, 5:58 PM
athomas's Avatar
that what i'm thinking it is. today the guage was working like normal. as far as warranty goes 89000 miles on the truck so this is going to hurt.
farmalcrazy
December 19th, 2008 8:52 PM
shanael1
Express & G-Series Vans
August 30th, 2008 5:14 PM
royschevy109
February 22nd, 2008 7:08 PM
Rick23
November 20th, 2006 3:38 PM
akobak
January 31st, 2005 9:00 PM
Quick Reply: temp guage
Top
Follow Us
