Old Aug 10, 2015, 6:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Towing & Hauling Guides
Print Wikipost
towing capacity
Old Apr 4, 2010 | 11:51 AM
acc2108's Avatar
Default towing capacity
i nedd to know what the max towing capacity is for a 2004 silverado 1500 5.3L
Old Apr 4, 2010 | 2:45 PM
s34n's Avatar
book should say. do you have 2wd or 4wd?
Old Apr 4, 2010 | 9:38 PM
wellmax's Avatar
to determine your tow capacity you will also need to know your differential ratio.
the code is listed on a tag in glove box on many models.
fine your code and someone on forum can tell you the ratio number.
Old Apr 4, 2010 | 10:37 PM
s34n's Avatar
Gq1 -- axle rear, std ratio
gt4 -- axle rear, 3.73 ratio
gt5 -- axle rear, 4.10 ratio
gu4 -- axle rear, 3.08 ratio
gu5 -- axle rear, 3.23 ratio
gu6 -- axle rear, 3.42 ratio
g80 -- axle rear, limited slip (positraction)
hc4 -- axle rear, 4.56 ratio
Old Apr 7, 2010 | 9:12 AM
davbell22602's Avatar
Look at GCWR rating thats on the rpo sticker in the glove box.
Old Apr 7, 2010 | 6:31 PM
s34n's Avatar
or check that rating on your door sticker
Gaz
Feb 11, 2019 9:26 PM
brocnizer
Apr 30, 2009 11:04 PM
ChevySoldier
Jan 8, 2008 5:58 PM
07summitwhite
Jul 20, 2007 12:28 PM
jorgie5150
May 30, 2006 3:42 PM
