Truck won’t go in reverse. Other gears ok
hello, we have a 1999 Chevy 3/4 ton 2500 automatic v8. About 2 months ago, it stopped being able to go in reverse. Other gears work perfectly. Naturally, I assume it’s the transmission, but is that the only possibility? Like I said, the other gears are fine. No issues
A faulty sensor will prevent this from happening, and you may see a check engine light in the instrument cluster. Also check for dirty transmission fluid and damaged reverse gear.
samger2
Silverado & Fullsize Pick-ups
August 11th, 2009 11:49 PM
