Old Aug 10, 2015, 3:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering & Suspension Guides
Print Wikipost
upper control arm bushings
Old Feb 11, 2011 | 3:26 PM
jljbtm's Avatar
Default upper control arm bushings
I need to replace these bushings, is there a special tool needed, or is this job a PITA, or do you just but new ones loaded?
Any recommendations?
this is my 1995 std. cab 2500 4x4
Thanks , Jack
Old Nov 10, 2011 | 10:38 AM
DCSCO's Avatar
J-
I'm asking the same question, what did you do? I am replacing the UCA Bushings and ball joints while I'm their. Loaded arms come with ball joints.
dc
Old Nov 10, 2011 | 12:14 PM
country_09's Avatar
They have to be pressed in as far as I know...if you have to replace both ball joints and bushings, I'd just assume to get another UCA with em already in there
Old Nov 11, 2011 | 8:29 AM
acer9876's Avatar
replacing the bushings.... a floor jack will be your best friend. other than deep sockets, tahts all you need. you will have to lower and raise the control arm through out the job, so that everything will fit in place
Old Nov 11, 2011 | 5:44 PM
DCSCO's Avatar
New to me '95 K2500. More play than I have ever seen in passenger UCA. Received bushings, ball joints are allready bolt in. I'll be going the press route this time.
Old Nov 12, 2011 | 7:24 AM
96 Junk That Moves's Avatar
I'm getting ready to do a complete front end rebuild on my 96 ( has 259K ) on the original parts and it's getting real loose. It is my understanding that a press works better than any other method for removing and replacing UCB's and LCB's bot I have used a large vise to do this job. Not easy but doable. Also soak the bushings with PB Blaster or Deep Creep for several days before-hand and it will help the old bushings to come apart easier. Just my 2 cents. You'll also need a BFH.
Charlie
Old Nov 13, 2011 | 7:11 AM
DCSCO's Avatar
Was able to take the UCA 45 minutes to a press. What a great device. Used various sockets to press bushings out. To press in, cut 2" tail pipe about 1". Took two to compete. Tail pipe went over the outside plate and caught the inner plate.
Large vise would do it if you have enough sockets, tubes etc. Since brother had press, not a issue. Saved $$.
Wills.WindowsAndWheels
Aug 22, 2013 11:37 PM
rjcisternas
Nov 14, 2012 1:46 AM
dcoperator
Oct 14, 2011 6:34 PM
waitery
Jun 30, 2009 4:29 PM
