Whats the right Tire pressure
Old Aug 20, 2010 | 8:10 AM
Dopeoperator's Avatar
Default Whats the right Tire pressure
When airing up my tires which pressure is it best to go off of the tire pressure indicated on the trie or on the door panel? I have heard from different friends to use one or the other. I typically dont haul heavy loads and keep my truck on the street for the most part right now. Thanks for any input
Old Aug 20, 2010 | 11:11 AM
Official GM Rep
That would depend on whether or not you have the original tires on the vehicle. If so use the pressure listed on the sticker in the drivers door jam. If they are not original tires then I would suggest you use the manufacturers suggested tire pressure. I hope this helps you.
Jeff Morris, Chevrolet Customer Service
Old Aug 20, 2010 | 6:56 PM
tsduke's Avatar
Tire manufacturers don't have a suggested tire pressure, just max psi.
Old Aug 20, 2010 | 8:33 PM
Mille Racer 69's Avatar
tire pressure for our truck tires can be between 40-80psi.
If the max psi is 80, pump it up to maybe... IDK, it depends on if you haul stuff alot
or have alot of passengers.
here, look at this:
Old Aug 21, 2010 | 9:13 PM
Thanks for the info. I dont typicaly haul heavy loads or go mudding often right now . I will keep that in mind. Thanks again
Old Aug 22, 2010 | 7:03 PM
s34n's Avatar
also depends if you have passenger tires or lt tires. what kind of vehicle do you have?
Old Aug 22, 2010 | 8:19 PM
MDTAHOE's Avatar
Professional Mechanic
Always go by the door. The tire only lists max cold pressure and nothing else.
Old Aug 22, 2010 | 9:14 PM
Seems that most road tires are between 28 to 34 psi, but as Mille Racer 69 posted image shows go by what kind of wear you are getting.... the door placard is just a rule of thumb but your load and temp range are going to have some bearing... in the summer here in Texas where its been 103 every day I have to adj the pressure down a bit to keep it in range but come winter when we get the bitter bitting cold days of the 50's I might have to add a bit-o-air...
Old Aug 22, 2010 | 10:26 PM
LARIDERS's Avatar
x2 if your not towing that should work good. you can always ask your tire store.
thompjs
Jul 6, 2015 11:18 AM
psciuto
Feb 8, 2015 9:25 AM
Jeremy3040
Jan 6, 2015 6:28 AM
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
davew2
Jun 16, 2011 12:16 AM
