Old Jul 27, 2015, 2:28 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Won't Start NBS
Old Jun 29, 2009 | 6:52 AM
Chas1955's Avatar
Default Won't Start NBS
I know we had alot of post on this awhile back & I have an update (Sort of). I had the problem twice over a year ago & none since. Now it's 100+ in Texas & still no problem she starts every time.Friday I took her to the dealer to have some waranty work (Windshield wiper fluid heater harnes) and as an after thought I told them about it not starting. They found a dead cell in my battery, now I know hot weather is hard on batteries,but to go 1/2 of winter & 1/2 of summer with no problem then have a dead cell? Was it dead a year ago and was still starting her?
Charlie
Old Jun 29, 2009 | 9:57 AM
therewolf's Avatar
Extreme heat and high humidity tend to take their toll on battery connections and wires.
Check your negative cable and your engine/firewall ground strap particularly carefully.
Late 06, all 07,all 08, half of 09 is almost three years, the bare minimum for corroded cables and wires under optimum conditions.
I would suspect the engine ground strap, especially if the truck gets offroad use.
Old Jun 29, 2009 | 6:54 PM
Chas1955's Avatar
Thanks for the info, but I work with batteries everyday. My truck had the first issue of not starting with 15,000 miles I had the radio on about 25 min. between sesions at the track. Turned it off & no lights were left on & it was dead when I tried to start it. Next time I was on the track helping tear down after a MC race with my flashers on (not longer than 1 hour) & it was dead again. This was last summer in Texas & yes it was hot,but after we got it started it was fine the next 10,000 miles. Summer & winter as an after thought I had the dealer look at it & it had a bad cell, but it was still starting every day in 100+ heat.
I know in some older post alot of NBS Silverado owners were having the same problem & was just trying to give an update & see if anyone else was still having the problem!
All your points are valid, & someone withan older Silverado may find them of use.
Thanks Again
Charlie
Old Jun 29, 2009 | 9:18 PM
shawnvw's Avatar
Banned
Thanks Again
Charlie
If you're so knowledgable about batteries, why are you asking questions about them?
Rivereye posted some very good info that DOES apply to your truck. I have seen poor grounds cause funky things at 100km....So even you're NBS may find them of use at at least 25000 miles.
Old May 12, 2010 | 11:38 AM
Chas1955's Avatar
Default Thank you
All I'm saying is I along with someother people have had battery problems. If it was a bad ground why would it start for the next year (0) -(110)F because bad grounds do not fix them selves. Also the dealer said I had a dead cell, but the truck started in HOT & Cold weather?
Charlie
PS
Yes I know alot about Batteries, but not the wiring on my 2007 Silverado! Now my 55 I can take it apart & put it back togeather blindfolded. I also know the wiring inside out & it does not have a computer? Hummm could that be the problem?
ZChevyAK
Nov 13, 2015 6:45 PM
bracca
Jul 12, 2009 6:14 PM
FamilyOf5
Jun 11, 2008 2:56 PM
bobinpa
Feb 16, 2007 11:58 AM
