'00 Driver side power window
My driver's side power window magically quit working one day. After unplugging the toggle switch from the wires and testing the wires w/ a voltmeterI found that there is no power getting to the driver's side window. The passenger side shows power and works just fine. I've checked all fuses that I think need to be checked and don't see any obvious signs ofbare wires. Am I overlooking a fuse? If not, where else should I look?
RE: '00 Driver side power window
I have a 2002 2500Hd Crewcab. and The passenger side front window motor burned out. While troubleshooting I found there was a relay also in the driver side controls that can affect all window motors. You should look into that to make sure it hasn't gone south. I never did find a burned fuse, even though the motor burned out, from being over loaded by a binding cable in the riser. Good luck in your TS.
Mel
Mel
2000YukonXL
July 10th, 2024 4:20 AM
Dan Cina
March 12th, 2013 1:00 PM
lacelles
July 12th, 2007 10:35 AM
