00 Silverado 5.3 - Rough Idle
Old May 28, 2019 | 3:44 PM
f4u5t's Avatar
Unhappy 00 Silverado 5.3 - Rough Idle
I have a 2000 Silverado Z71 4x4 with the 5.3 and it has developed a rough idle.
I have replaced the Throttle Position Sensor and just finished installing new plugs and coil pack wires. None of which helped much...
It runs fine other than that.
Looking for suggestions of what else I may try..
Other issues that I think are unrelated but mention anyway...Automatic Trans ( 4l60e) does not shift from 1-2 when accelerating, soon as i let off gas it does fine..Ive replaced teh trans, which DID NOT fix the issue, it did for about 2 months but the issue has returned.
Gas Gauge is erratic, was fine before trans replacement but now is wonky.
Old May 28, 2019 | 7:19 PM
oilcanhenry's Avatar
Are you showing any OBD II codes at all? Could be a vacuum leak somewhere, like intake, EGR issues perhaps,
Old May 28, 2019 | 7:29 PM
Irish_alley's Avatar
I'm here for the party
could be even something as simple as a grounding issue. start with the basics, if it started after the trans replacement look for any grounding straps that are just hanging or loose wires
Old Oct 7, 2019 | 8:58 PM
f4u5t's Avatar
i never have found the culprit....any other ideas
Old Oct 8, 2019 | 4:10 AM
What exactly is the gas gauge doing?
Mikeh61
2007 - 2013 (GMT900)
Jul 19, 2019 8:50 AM
rross8085
Mar 8, 2016 10:44 PM
mn808gade
Jul 21, 2012 1:43 AM
jesse06
May 16, 2012 1:29 PM
benwr3476
Dec 19, 2008 8:10 PM
