00 Silverado Cold Start Problem
Old Dec 2, 2014 | 2:58 PM
jtlonghorn's Avatar
Default 00 Silverado Cold Start Problem
My truck is having problems starting in temps 32F or less. It turns over but won't start. Once it does start (if it even does) it runs fine. Here is what I know it is not as I've replaced....
Battery
Fuel Pump
Fuel Filter
Fuel Pressure Regulator
Spark Plugs
Cleaned MAF
Tested Engine Coolant Temp Sensor
Installed Engine Block Heater Plug...no difference
Thoughts????? Even though I cleaned the MAF, I tested the first two prongs for resistance and got nothing......so maybe MAF? I'm not sure what else to try.....
Old Dec 9, 2014 | 8:18 AM
02HD's Avatar
Gasoline engine ? Pull a vaccum on the engine and look for an intake leak. I had the same problem you describe here a couple years ago, faulty intake gasket. Once the engine starts the the problem was gone in seconds. Made it very difficult to diagnose.
LanceV
Aug 24, 2011 12:59 PM
gtfireman
Feb 3, 2011 5:18 PM
Thermool
Jun 20, 2009 6:41 PM
izod
Feb 14, 2009 2:42 PM
carlsndfw
Dec 7, 2006 7:43 PM
