'01 with many different starting troubles
I have an '01, 1500, 4.3 liter with about 145k. Lately, when starting, the engine will crank but has a difficult time turning over. Once it starts, it will be good for the day, but every morning is a gamble if it will start or not.
Recent troubles have also developed. Last couple of days, I have had occasions when the truck would start, but would quickly die because there is no fuel pressure (that's what I'm guessing ~ truck won't even idle). I have been able to drive it with by keeping my foot on the gas when stopped. I would have to do this for about a couple of miles and then the truck will idle fine.
Today, I had troubles starting the truck again but this time I notice smoke coming from under the engine as if something was burning. I could not make out what it was.
Any ideas????
Any ideas????
When was the last time your truck had a full tune up? There are many things that can cause what you are talking about. You say that it is a fuel problem and this usually caused by a bad fuel pressure regulator. There is also a check valve in the fuel pump which could go bad. That is what happened to my 99 4.3. I put a check valve in the fuel line just before the filter and now it starts great. This might be your problem.
Wakko
April 7th, 2014 10:15 AM
jcskys
January 2nd, 2009 4:04 AM
khelms_98
February 14th, 2007 4:12 PM
