03 6.0L Problems Starting and 'diesel" when shuts off
Old Apr 11, 2011 | 12:47 PM
Chevrod's Avatar
Default 03 6.0L Problems Starting and 'diesel" when shuts off
The truck is a 03 chevy 2500HD 4x4 with the 6.0l around 100k miles. Seems to sputter and not want to start on the first try sometimes like it is not getting enough fuel and if I do not shut it off in gear it will "Diesel". Also since this issue has started the truck seems to be underpowered. Has not thrown any codes yet. I was thinking possibly the throttle position sensor or maybe the gas tank is not venting right? Any help or advise would be great thanks
Old Apr 12, 2011 | 2:57 PM
Doug Mercer's Avatar
check your injector O-rings. I've seen the same issue with a little 4 cyl. It is hard to start and lacks a lot of power. Also check the continuity in you wire leeds.
Old Dec 11, 2011 | 9:29 AM
Bryan77's Avatar
New User
Awaiting E-mail Confirmation
Talking hard starting diesel
I have two of these trucks and have had the same problem,my fix was the prime button has rings under when you remove the 3 screws to the button.replace it, the c ring will still be ok so don't
trouble your self finding
one of those.
damone
May 8, 2021 12:36 PM
dbanks17
Jul 9, 2015 1:05 PM
pjbizjak
Oct 27, 2011 11:14 AM
kornbred6
Feb 28, 2011 1:32 PM
gunrnr
Aug 31, 2010 9:18 PM
