03 Silverado 5.3L speed sensor
Old Oct 11, 2011 | 8:45 PM
ragant20's Avatar
Default 03 Silverado 5.3L speed sensor
where is the speed sensor located at on an 03 silverado i thnk i need to replace it?
Old Oct 12, 2011 | 11:18 AM
EinST's Avatar
I assume you're referring to the vehicle speed sensor (VSS). The VSS is mounted on the tail extension of the transmission or, in the case of 4WD, on the transfer case. It takes a two-wire (PPL/WHT and LT GRN/BLK) electrical connector.
Old Oct 13, 2011 | 12:58 AM
ragant20's Avatar
ok thanks alot got it switched out
Old Oct 13, 2011 | 5:18 PM
EinST's Avatar
You're quite welcome. Hope it works out for you.
walter_simmons
Jan 22, 2015 6:18 AM
bass1
Jul 28, 2014 4:02 PM
bass1
May 25, 2014 6:21 AM
deepstuff
Sep 24, 2011 8:43 PM
schwhack
May 28, 2008 6:44 PM
