'03 Silverado Cluster Replacement issue
Old Jan 22, 2016 | 1:27 AM
The1Demz's Avatar
Default '03 Silverado Cluster Replacement issue
So I am currently undergoing the process of changing out my cluster due to the old one shorting out and throwing smoke. That being said, I know that in order to order a new cluster, the mileage, VIN, and engine hours has to be given to the supplier to ensure the new cluster shows the correct mileage. However, the circuit board on the old one is fried and does not turn on, does anyone know what i can do so that i cant be penalized by the DMV for altering mileage? Or if there's an alternate way to get the mileage at least?
Thanks!
Old Jan 22, 2016 | 8:15 AM
cleveland63b's Avatar
you can get the mileage with a scantool in most cases, otherwise you can just guess or start at 0 as long as you put a sticker/label on the door jamb stating that the odometer isn't displaying the accurate mileage you should be fine, GM has a bulletin about it I remember seeing a while back
Old Jan 22, 2016 | 8:24 PM
The1Demz's Avatar
Update: DMV in Cali stated that i could put the sticker on the door jamb and disclose that the mileage on the odometer was not accurate so that i do not get penalized.
Thanks!
Old Jan 25, 2016 | 8:43 AM
Tanin Auto's Avatar
Former Sponsor
Thanks!
Hi, Tanin Auto Electronix here, we are vendors on the site. We can assist you not only with the Silverado cluster repair or replacement if it is not repairable, but also with odometer correction as well. See our diagnostics link to your gauge cluster and speedometer repair service here:
Diagnosis
Let us know if you have any other questions. We are happy to help answer them for you.
Thank you,
