04 Silv 5.3L 1500 Gas Fill problem
Old Aug 19, 2009 | 11:10 AM
Vahalla's Avatar
Default 04 Silv 5.3L 1500 Gas Fill problem
What should I do? I can't put more than 2 gallon a gas in at a time. The fill tube is gurgling and the pump handle keeps shutting off. What causes this?
Old Aug 19, 2009 | 11:24 AM
myotherchevyisablazer's Avatar
have you recently had the fuel pump changed?just my experience ..after i changed the fuel pump out.. it started doing it as soon as i was ready to take her camping and driving 300 miles one way....i could only get around 10 bucks then it would kick the gas back out and onto the ground.......keep us posted if you find some interesting info...air is sometimes the culpret
Old Aug 19, 2009 | 11:30 AM
Vahalla's Avatar
I can't even get a couple gallons in. I think it is my evap cannister, but not sure.
A couple had a fight at a resturant, and the man left peeling tire in a gravel parking lot. Needless to say, he threw rocks all over my truck and my back window also was busted out from the rock spray. After i had it fixed this problem started. I don't know if the mechanic put the box on a line or what.
Old Aug 19, 2009 | 11:36 AM
sorry to hear about your truck ....what do you mean put the box on the line?im kinda slow/// evap can could be the prob..sometimes kinke dlines ..how it happens i donyt know...is your check engine light on?
Old Aug 19, 2009 | 6:32 PM
MDTAHOE's Avatar
Professional Mechanic
You can check the vent hose, it is the smaller one beside the fill hose. Also pull the fill line off the tank (it is held on buy a hose clamp) just inside the tank is a screen that sometimes gets a bunch of trash in it.
Vic2120
Mar 12, 2021 11:05 PM
Doug Mercer
May 13, 2011 8:42 PM
mbaker1057
May 29, 2008 8:24 PM
nonmechanic
Feb 5, 2007 3:28 AM
nonmechanic
Feb 4, 2007 8:07 PM
