Old Jul 29, 2015, 1:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
04 Silverado - Check engine light - no computer read?
Old Feb 6, 2012 | 12:48 PM
kalats's Avatar
Default 04 Silverado - Check engine light - no computer read?
Hello Everyone,
Looking for some advice on this one since its got me stumped.
So every couple of weeks my check engine light turns on in my '04 Silverado 2500HD-4WD. Its completely random. Nothing similar in conditions. But the weird thing is, when I connect a code reader to it there is NOTHING...I mean absolutely nothing. No code at all...anyone have any advice. I'm an official newbie so please bear with me.
Appreciate any help you can offer.
Thanks
K.
Old Feb 6, 2012 | 12:50 PM
EinST's Avatar
Welcome to the forum. "No code at all," not connected, or unsupported? What brand, model, firmware version is the reader?
Old Feb 7, 2012 | 7:23 AM
kalats's Avatar
Default The mystery continues
EinSt.
Thanks for the reply. Actually not sure what kind of reader it was. I simply went in to an Advance Auto Center. We plugged it in, and there was a blank screen. The person helping me out said the reader should automatically turn on when plugged in. We actually tried two separate readers with the same result.
Not sure if its an electrical problem? If so, how in the world can I find it...
Any help is greatly appreciated.
Thanks
K
Old Feb 7, 2012 | 11:41 AM
EinST's Avatar
So, the guy couldn't get his reader to connect, then, which is not the same as the absence of codes. Check the OBD data link connector for battery voltage on pin 16 (rightmost pin, bottom row as you view the connector under the dash) and ground on pin 5 (5th pin from the left, top row). If battery voltage absent, check the 15A CIG LTR fuse in the underhood fuse block.
Old Feb 8, 2012 | 8:15 AM
kalats's Avatar
OK. Thanks EinSt. Definitely appreciate your help. I will take a look under the hood to see if the fuse is burnt.
BTW. It looks like I'll be a regular visitor to this site, since I'm hoping to have my silverado for a very long time.
Thanks again.
K
Old Feb 8, 2012 | 5:54 PM
nj85z28's Avatar
Senior Site Administrator
I agree with the above and have also had that same problem, its the cig lighter fuse usually.
Old Feb 8, 2012 | 6:22 PM
Doug Wells 69's Avatar
Just had the same issue on a 1999. Replace the cig lighter fuse.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
harlee22
Jun 16, 2014 7:40 AM
101btp
Nov 30, 2010 8:36 PM
mitchdakid
May 22, 2009 1:45 PM
