Last edit by: IB Advertising
Browse all: Steering and Suspension
- Chevrolet Silverado 1999-2006 GMT800 How to Install Tie Rod Ends
Step by step instructions for do-it-yourself repairs.
05 Silvy 2wd tie rod removal...
Ride of the Month
August 2009
August 2009
What tool should I use to remove the tie rod from the rack? I dislodged the taper from the spindle, I'm just wonder how the heck to remove the other end from the rack. I figured before I go in there and try my own methods I'd ask around here. Any help would be appreciated. Thanks
I'm asking cause I'm installing the Mazzulla LT kit on the truck, pics of the build later.
Deez
Deez
Three methods I know of:
Borrow, buy or rent the proper sized "Pickle fork".(There's ball joint sizes, and tie rod sizes)
Back the nut off a few threads, and with it still on the end, whack it with a hammer. Not the most successful, and not generally recommended.
Take a large vise grips, vise it onto the end you're trying to remove, and whale(wail?weep?) away with a large hammer.
Method #1 is highly recommended by most.
ok, you have tierod end removed from the spindle, right?
do you have rack-n-pinion?
if yes, you have tierod end and tierod.
you have tierod end removed (dislodged?) from the spindle?
tierod end then simply screws off the tierod.
tierod end should screw out of the rack. brake the clamps that holds rubber boot in place to slide rubber boot off and get to guts. then, simply, use hose clamps to put rubber boot back on.
if you have g'ol parallelogram steering, with steering gear and idler/pitman arm and connecting rod, tierods screw out of connecting rods. we have done it some six mths ago, piece of cake.
Ride of the Month
August 2009
August 2009
Deez
1. remove the dust boot on rack-n-pinion assy; basically, break clamps loose and then, like i said, replace them with regular hose clamps, unless you just want to buy crimping tool for OEM clamps
2. slide dust boot off rack and as far off towards the tierod end, as you can, to access the connection between tierod and rack
3. there should be a ball type joint where tierod connects to the toothed rack. parts stores will rent you a special tool for this, with instructions, if tierod does not turn out from hand.
4. roll tierod on a piece of glass. if it rolls smoothly, it's good. if it wobbles and clunks - you have to replace it.
if your boot has a breather tube, you must reinstall boot exactly same position it was on originally.
of course, alignment follows next, but you know that. i did tierods twice, once on rack-n-pinion and once on parallelogram steering, both times tierods just turned out from hand. but they must have some reason to have that tool available, you might need it for your situation.
Ride of the Month
August 2009
August 2009
Thanks, I'm replacing the old tie rods and tie rod ends with heim steering tie rods(for the long travel kit) so no need to be gentle. I haven't even tried unscrewing them by hand. lol Guess I should of thought of that, oh well. Either way I'll get it off, no need to spend extra money at a parts store when I'm not reinstalling them anyway. Thanks.
Deez
Deez
