Last edit by: IB Advertising
Browse all: Powertrain Guides
- Chevrolet Silverado 2007-2013: Why is My Oil Pressure Low?
Guide to diagnose trouble and recommended solutions
05 Siverado oil pressure too high
Recently my oil pressure guage started showing 80 psi but when i turned the ignition off the gauge would only go back to 40 and not all the way to zero. I changed the oil pressure sending unit and now the neddle goes all the way past 80 and as far to the right as it can go. Do you think it is the gauge or could it be something else?
sounds like the stepper motor is going bad in the gauge. you can check by putting a mechanical gauge in and see what psi you have, or use a scan tool.. my money would be on a bad gauge/cluster..
good luck
good luck
not_a_car_dude
September 15th, 2013 7:41 PM
mprovence
11
October 9th, 2012 1:24 PM
Mille Racer 69
15
January 1st, 2011 9:12 PM
mygreenihc
May 7th, 2009 9:41 PM
