06 silvy low on oil but not leaking
i have a 2006 silverado with 51,000 miles.i change the oil regularly.. but today it said check oil level ..so i did..and it was really really low..but i dont' burn black smoke from the exhaust and i am not leaking antything underneath where the oil pan is...although in idle..a little smoke comes up..but light gray almost white..like when its cold and you breathe..that color..so..any help or suggestions would be awesome
RE: 06 silvy low on oil but not leaking
Did it just start doing this?
How much oil is it consuming? Such as 1qt every 500 miles or 1,000 miles or 2,000 miles etc?
Do you notice any gray smoke (not steam) when you first start it after it has sat for several hours?
as far as the consumption..i couldn't tell you..i would have to start keeping track..i started using synthetic since the first oil change when i bought it brand new. dont know if that would make a difference..but sometimes smoke does come out the exhaust when i first start it up after it has sat...but light smoke..not dark..and not alot..if it is the switch..is that something i can change or have to take in to the dealer
A faulty oil pressure switch will not cause oil consumption, if it is not sealed it may cause a leak but you said that you don't have a leak.
My best guess is that there were some 5.3L engines that were assembled with faulty valve stems, if this is the case both cylider heads will need to be replaced.
Have the dealer reference GM Document ID #1961494 for more information, if your engine is effected by this then there is a good chance that GM will cover the repairs as a good will gesture even though you are out of warranty, if you have an extended warranty then it should cover the repairs provided the oil consumption is beyond acceptabe levels which are no more then 1qt in 2,000 miles.
Synthetic oil has nothing to do with this.
GM repair Manual says it will. Course it could be wrong. I don't know for sure my pig just leaks never had an issue with the switch.
thanks for the info.much appreciated..i will add some oil..but i think i will have chevy look at it..and see..i got the extended warranty..just incase something did happen..soo..i hope its nothing major
cdcpedroso
February 11th, 2022 11:18 AM
Jeepking88
May 19th, 2014 3:11 AM
DeeZ
April 24th, 2009 11:02 PM
larry_chip
April 24th, 2007 11:46 AM
